Dagu Mini Driver Issue
Hi! My first post is nowhere to be found so I am posting again. I recently obtained the Dagu Mini Driver board based on the Atmega8 and uploaded the code from the getting started tutorial, the one that makes it go it a square. It uploaded perfectly.
Then I attached a 4x AA battery pack to the battery header connection, observing polarity. My multi-meter read 6.31v for the batteries...good to go
. I also attached these motors(link bellow) to ML and MR headers. I powered the board on, but the motors didn't budge. I uploaded the blink sketch to make sure the bootloader was good and it uploaded perfectly also. So I uploaded the old code again. I let it sit for a day.
The next day I tried with a different motor and it worked! I thought, maybe I did something wrong the first time or something. So I attached the wires back to the original motors and tried it. They worked also! But after about 5 minutes of non-continuous driving they stopped moving. It wasn't sudden, it was after turning it off, and then on again. I tried the other motor that is had started working with and it did not work either.
I assure you the connection to the motors was secure. Also, the light on the board, the red one, always lights up.
So, as you can guess, I am totally confused.
What could the issue be? The only thing I can think of is to high of a stall current maybe?
Link to motors I used:http://www.allelectronics.com/make-a-store/item/dcm-427/6-12-vdc-motor/1.html
