2x 8" Heated Bed questions
Discussion in '3D printers' started by Airsmith, Jan 13, 2014.
  1. Airsmith
    Airsmith New Builder
    Hey all,
    Just wondering if it's possible to place 2x 8" heated beds, side by side, by creating a larger build plate, and is there a second spot on the mother board to plug it in? Also, how does this affect power consumption?
    Thanks.
  2. Nick Lancaster
    Yes you could run 2 heat beds, but you would have to be sure they are within the amp rating of the board. Most likely there is only 1 connection for the heatbed on the printer board. So your best bet would be to use that output to switch a higher rated relay to run both heatbeds.
    Airsmith likes this.
  3. Airsmith
    Thanks for the reply Nick.
    Now back to the drawing board...
