All orders for the US will go through Open builds to save on shipping costs. The board is an exact copy of what I'm using to control my Laser V project. http://www.openbuilds.com/builds/laser-v.226/ My Hex file will be located in the build log for upload to your Arduino. I will no longer be offering the Nanos and Stepsticks as the wait time is to long for the demand. I feel it's just cheaper for you to source and you should know / learn to upload and configure GRBL anyway to truly use all of its features. Shop around and I'm sure you will find a great deal with pins installed. Laser V will come pre set @ 150ma and can adjust to 1 amp +\- 5% The driver adjusts in a counter clockwise fashion "increase of current" as most people in a panic turn things "off" clockwise, you don't want to turn the current up in a panic because your laser is to hot or other issues that may arise as you tinker 18+PLEASE TAKE ALL CAUTION LASERS ARE NOT TOYS! Use at your own risk. One stray beam could mean the last time you see. Safety glasses are a must! http://bit.ly/1aUJlXA I recommend using it with a 445nm diode as that is what the diver is ment for and will not burn it out. "I take no liability for burnt diodes" All boards look as pictured excluding the stand offs You will require a Arduino nano and 2 x A4988 stepsticks to complete the laser shield. http://bit.ly/1aUJSJ2 http://bit.ly/1aUJYQZ Micro stepping info http://www.pololu.com/file/download...ping_driver_with_translator.pdf?file_id=0J450 Pinouts NOTE: Board needs a dedicated USB port as the relay is powered from the arduino
Here is my GRBL Hex file and a copy of X Loader Im also working on a PDF of the PCB layout for any do it yourself folk A list of all the parts needed are in the build log.
Limits! So for the folks that would like to use hardware limits in grbl for homing you will need to disable the Z axis in the homing section of your config.h file. Here is how you can do it Look at the config.h file. There are a couple of 'defines' that set up the homing cycle. To get rid of the z-axis, comment out search cycle 1 and change the following. #define HOMING_SEARCH_CYCLE_0 ((1<<X_AXIS)|(1<<Y_AXIS)) #define HOMING_LOCATE_CYCLE ((1<<X_AXIS)|(1<<Y_AXIS)) Compile and flash to your Nano I hope this helps For now I use software limits but will be updating to hardware and then will mod my hex as said above. When I do, it will get uploaded to the files section of my build log.
A little walk through on setting up your board and it will be updated with info as questions arise. Before you can use your LD2X you must setup your arduino nano with GRBL, see attached files in the Laser-V build There will be a pre compiled hex that I created along with a copy of the source files for you to compile your own if need . The only thing compiling is needed for is pin assignment and other core settings. Changing parameters are all done through your console "grbl controller, gcode sender ex" by typing $$ and hitting enter. There you will see a list of changeable settings. "DO NOT HAVE NANO PLUGGED INTO LD2X WHILE UPLOADING HEX" So on to uploading the hex Plug in your arduino nano via USB and install the drivers, windows should have a driver on file for it and auto install them for you. Next you need a copy of Xloader again in build files. Open Xloader direct to where you saved your hex, select the com port your nano is connected to and hit upload. It takes a little bit, then you will see that it has completed the upload and you should now be sporting your own GRBL nano. Plug in your nano to the LD2X, open console, select port and then open. A grbl message should pop up"grbl 0.8" Type $$, hit enter, If a list of options pops up you installed things right. A fast test of your laser driver contact can be performed by typing M03 ENTER to turn it on M05 ENTER to turn it off "Should hear relay click" When it comes to the stepsticks, simply pic your micro stepping setting using the jumper pins located in between the driver board sockets for each driver, then plug it in/set your current and your ready to rock. Please refer to the above pic for connection pin outs as there is no silk screen on the PCB Plug in your motors, wire your 12-14.5 vdc and your ready to play. If you have wired your diode, put on them protective glasses before playing and adjust your driver to the correct current for your diode. If you are following my advice and using this board with a 445nm diode your safe to adjust the current with out a dummy load as max current is 950ma and m140 can handle about 1.5 amps. Test your motors by typing some simple commands in the console " G1x10y10 ENTER" If your motor driver current and step settings are right then you should have seen your motors turning Setting your output volts for any other diode can be done by turning on the laser contact and putting a multi meter across the LD output. Adjust the voltage trim pot to desired output. Adjusting the current is done in the same manor but a dummy load must be applied, resulting volts translate to current. Please see link for better understanding the laser driver side of things. http://laserpointerforums.com/f42/diy-homemade-laser-diode-driver-26339.html
Sorry for this "off topic", but I wonder what materials and/or processes are using to make this board. I'm trying to make one and even if not using a router or a copper foil on acrylic. Thank you very much!
I use a positive resist method for my PCB boards, but hope to be milling them soon After exposing the boards with my UV unit I etch them in hydrogen poroxide and pool acid 2:1 ratio, etchs fast and lasts longer
ok thanks. I will get my power supply ordered today.... Now I just have to wait for the 8mm screws to get restocked to place my order.
@Robert Hummel That is great. It is going to take at least that long to get the rest of the parts. Thanks for the Help.
A good 4 - 5 inch of space is good as smoke hitting your lens will destroy it. Be sure to incorporate a exhausting fan to whisk smoke away.
Yes to an exhaust fan! You should probably also consider using a lens mount/nozzle with the a fitting for "air-assist" like the following: http://www.lightobject.com/1820mm-Laser-head-w-air-assisted-Ideal-for-K40-machine-P701.aspx.. This is what I've been using on my buildlog.net 2.x laser. I'm very happy with it. I'm using an aquarium air pump to push air through the nozzle.
Probably! I missed the diode part...I only saw the smoke and lens part. However, it's always a good idea to keep smoke away from a lens on any laser. Obviously it more important on a 60W CO2 laser.
@Robert Hummel looking at this board I am thinking about the best way to control it. If I am wanting to say etch and cut on balsa wood or foam board would I just speed it up etch and slow it down to cut?
@Robert Hummel I powered on and ran the m03 command and the lm317 by the Arduino nano got very hot. Is that normal?
