Mini V Linear Actuator
Discussion in 'Other Builds' started by kram242, Aug 1, 2013.
    kram242 published a new build:
  2. Murat
    Murat New Builder
    Hi,
    I want to build same system with 20x60 mm . Which parts should be change?(i want it 1500mm length option) I should buy it as soon as possible...It's an urgent issue...
    Hello @Murat
    If you download the model under the File tab above there are a lot of examples built in there for you (20x60 examples as well).
    The parts list will be the same (Parts list tab above) with the exception of the length of the belt depending on the length of the V-Slot you choose.
    To get the belt length, measure the length of the rail then double it and add a little more in case (12" is more then enough)
