Stinger V Micro Mill
Discussion in 'CNC Mills/Routers' started by Robert Hummel, May 10, 2014.
    Robert Hummel published a new build:
  2. Tweakie
    Excellent build Robert - I just don't know where you find the time for all these projects. :)
  3. oni305
    very cool!
  4. Dave M
    Dave M Well-Known Builder
    Awesome. You Rock Dude! You inspire us.
  5. mybuild14
    mybuild14 Well-Known Builder
    Great job Robert. This is a perfect choice for a newbee or a professional or anywhere in between. Watch out when word gets out the orders will be stacking up. "Thumbs Up"
  6. Anthony Webb
    Anthony Webb Well-Known Builder
    Dibs on the first set of brackets, where do I send my cash?
  7. skrider
    skrider Well-Known Builder
    Wow, very vice build! I love some of the custom parts you've designed, and beautiful work as always!
  8. Anthony Webb
    Curious what your cutting envelope is on this little guy?
    Not sure yet but it can be made as large as one wants.
    I just wanted to use up all my spare odds and ends.
    I would guess at about 12 x 14 inchs
  10. Brian Slee
    Brian Slee Journeyman Builder
    Nice Build Robert
  11. Anthony Webb
    One worry I have about the Tension 20 design is that it appears to only be adjustable from the inside. Have you found instances where they are not easy to tweak on after they have been installed?
    Wondering if the adjustment grooves would be better placed in the plate itself, and the threads in the Tension 20 so you can tweak on stuff from the outside? Just a thought as I've studied over the screenshots.
  12. Robert Hummel
    I did think of that but I would have needed to make two different tension designs so I did my best to allow room.
    You would need a stubby Allen wrench for tweaking down the road from wear.
  13. Anthony Webb
    As long as you can get to them without disassembling stuff I suppose it is not a big deal. Excited to see some more details!
  14. mkolsen22
    mkolsen22 New Builder
    This looks to be an awesome build. Can you share with us the lengths and cross sections of the extensions used as built? Also, I presume that this is designed for the NEMA 17 steppers. Thanks for sharing your talent with us.
  15. silos
    silos New Builder
    Hello. I have been reading up on all of the builds on this site. Yours seemed the most rigid. Can either this build or the OX build mill aluminum? Is it rigid enough to mill the OX side plates as the original CNC (with the liquid cooled spindle) did?
    I am looking into building a CNC router to be able to mill an unibody aluminum laptop case(like the macbook pro).
  16. Anthony Webb
    Anything so far you wish you had done a little differently? Looking forward to an in depth review.
  17. Robert Hummel
    As of yet not really, I need to replace all the v wheels still and finalize the controls before I can really say anything.
    It is super solid that's for sure and the Nema17 motors from the builds store are quite impressive.
    I'm also real happy with the Z leadscrew, moves smooth and fast even at 1/16 step rates :)
    I will say that I was hoping to find a smaller RC motor for the spindle that wouldn't take up to much space but really making the Y rails an extra 50 mm long would make up for the lost cutting space.
  18. Robert Hummel
    So after some testing I know the X axis has 360mm of travel from limit switch to limit switch
    Also the RC Motor I plan on using for the spindle has arrived and I will be picking it up tonight.
    Same 890KV 5045 just a different style and make :)
    I will be saving the power supply I got from openbuilds store for my OX spindle and using 2 modified 250w rack mount power supply's one for the spindle and one for the controls.
    Jestah likes this.
