The length of the Aluminium Extrusion and v-slot rails.
Discussion in 'CNC Mills/Routers' started by Fishermon, Mar 8, 2014.
  1. Fishermon
    Fishermon New Builder
    Is it possible to get a custom cut of the Aluminium Extrusion and V-slot Rails of 10 feet, instead of the standard 2000mm offered? I want to build a CNC that can cut the sides of a tear drop camper.
  2. SlyClockWerkz
    SlyClockWerkz Journeyman Builder
    Vslot is only offered in 1000mm and 1500mm lengths
  3. Fishermon
    Thankyou for the quick response. Is the openrail also limited to 2000mm' and if its so, could I use two v- slot or open rail to acquire the desired length. Would the combined parts cause a bump in the movement of the wheels as they travel across the gap.
  4. SlyClockWerkz
    You need to look in their parts store. It shows you right On the product page what lengths their extrusions come in.
    You could always try a double tee-nut or a plate to make the connections, but like you said you would need to work on it get it smooth.
  6. Fishermon
    Thank you for the Lead. I check out the parts page.
    Welcome thanks for supporting the OpenBuilds part store :thumbsup:
