890KV OX RC spindle
Discussion in 'Other Builds' started by Robert Hummel, Jan 13, 2014.
  1. Nick Lancaster
    rotozip bits have more then 1 inch of side cutting area. But the spindle that Robert used will take 1/4inch bits, and those are available in many sizes including the bets of the betst. 65-026 Onsrud Single Flute 1/4inch SolidCarbide with 1.25inch cut depth. I would never try a cut more then probably 1/2in in depth on these style machines, I doubt they are strong enough to avoid chatter at that DOC.
  2. The Dude
    What do those people use to cut 2" foam? I know some use a hot wire but I think I saw a 2.5" bit with 0.25" shank.
  3. The Dude
  4. The Dude
    ooooooh pretty. Can't wait for the collet chuck to arrive.
    Daniel Porter and Robert Hummel like this.
  5. JustinTime
    In the PhlatForum there is a guy who is building an electric car from scratch. If I recall correctly, originally he wanted to make the body out of 2" foam section but couldn't get the right bit to do the cutting. I think he ended up doing it in 1" foam.
    If you have a link to a 2.5" bit, post the link, please. Everybody will be thanking you. lol
  6. Nick Lancaster
  7. Rick 2.0
    1/4"x2 1/4" (4" OAL) is fairly easy to find https://www.google.com/shopping/product/16267331210206391260?espv=210&es_sm=122&biw=1920&bih=1017&output=search&q=1/4" foam cutting bit&oq=1/4" foam cutting bit&ei=c7veUsu6IOWN2gXC_4G4DA&ved=0CH0QpiswAg
    If you want longer, you will probably have to go up in diameter.
    JustinTime likes this.
  8. Nick Lancaster
    Well I stand corrected on the 1/4in shank diameter :D
  9. The Dude
    DOH! Someone beat me to it. But now I know I definitely want 1/4" ER collet tool holder and not 1/8".
    I would get both as you can get a 3 piece kit off eBay for a good price and it will open your bit selection ;)
  11. The Dude
    Getcher motor runnin'. Here's the wiring diagram I used to get an Arduino to make the motor spin at various speeds. Oh man I messed it up. The white wire goes to the pin9 and the black goes to GND. sheesh. Motor Wiring.jpg
    Just a word of caution, these motors are extremely dangerous. I have mine bolted to a board and the board is clamped to my desk. I tried to run it without bolts/clamps and it took off like a wheel and almost smashed my monitor. You have been warned...
  12. The Dude
    Almost there.
  13. Robert Hummel
  14. Public Do Omens
    This is why when we build quad copters the opposite side goes in reverse.
    To balance the torque.
    Hold the motor in your hand and feel the head torque.
    This is why i have my Z axis down the middle of my spindle shaft. In relation to X,Y moving parts.
    Others might find this method allows for better torque control, as it is more balanced being on the Z - Axis center.
    When you move the Z Axis from the X, Y you are exaggerating the torque effect.
    Hold motor turn on, hand close to body. Then move the arm to full length turn it on, harder to control. You see.
    I think it is torque acting on a lever, when it should rotate around the spindle center @ x, y location reducing this lever effect to ZERO.
    :cool: interconnect.me.uk
  15. The Dude
    Yep, with washers on both ends. I left off the lock-collar for now and will make a clamp the same way they make scope mounts... maybe 6 screws holding it onto the v-slot. I'll have to add a right-triangular brace in the future to keep the vslot from flexing.
  16. Public Do Omens
    Is it not true if you reduce shaft length on the tool then you get less flex in the tool doing the work?
    This is what i would do, reduce errors by reducing long parts to shorter parts that have less flex. :cool:
  17. The Dude
    Yes, but the shafts you can buy are always long. The motor bearings are weak and can't handle a side-load so we use the extra shaft to add bearings and then the bigger bearings are coupled to the z axis. The actual distance between the tool and the mount is maybe 2cm. The top of the motor spins freely and the bearings all the way down are fixed to the machine. But yeah it kinda looks like this big long thing which is connected at the top so it has a huge torque radius... but that's not the case, depending how you mount it.
  18. JustinTime
    You are right, of course, the longer the shaft the more it flexes, BUT, it also makes it easier to give the shaft support. If you put a bearing, with its support, just before the chuck (or what ever you use to hold the tool), you are way better off than relying on the bearings of the motor and the motor will thank you by living longer. It's even better if you put another bearing on top of the motor. I tried it on my machine but since my machine is made of MDF I had aligning issues and had to take it out.
  19. The Dude
    Hey dudes,
    So I am getting ready to make all this and wanted to run it by you all to make sure it will work. I've got a double-fluted solid carbide bit with 1/4" diameter(6.35mm), some aluminium from the recycling centre (plate=12mm or 1/2" and block=37mm or 1.5"), and my spindle is mounted very cheaply with some bearings, hose clamps, and a steel plate at the top. I plan to use foam to test it and then maybe some wood and then finally this aluminum.
  20. JustinTime
    Dude, it will work fine. Just make sure you cut in many, shallow, passes at low ipm and use liquid to cool the cutting bit and material.
    How shallow a cut? That, my friend, you'll have to find out by trial and error.:ROFL: I would start with 1/64" at 5ipm and then go to 1/32" at 5ipm. If that works fine increase the ipm rather than the depth.
  21. ThinkerTinker
    ThinkerTinker Well-Known Builder
    Great build Sir!
    This just up my alley
    Iv worked with brushless motors for over a year for "non-RC" applications. This homemade electric longboard is what introduced me to DIY side of life :D I weight 150lbs and can get 27mph out of this little motor (25.2volts and 200A ESC), don't underestimate these little buggers, they'll nock your teeth out.
  22. Robert Hummel
    That is just awesome bud!
    As they say size don't always matter lol
  23. The Dude
    dang this aluminium is tough to mill. I had the feedrate way down to 100mm/min and it chattered the machine to the point of slipping steps and flexing the gantry. I believe 5ipm=127mm/min... so maybe I can try again at 20mm/min but now the v-slot wheels on one part have a little play that can't be taken up by the eccentric spacers... Does this mean the wheel is hosed or the hole is off or the screw is bent or what?
    A lot has to do with the bit, also the way your spindle is mounted.
    Not knocking ya in any way I feel you jumped into aluminum a little to quick.
    Where and how are the esentrics installed "plate? V-grove channel?"
    Odds of the bolt bending are low
  25. Rick 2.0
    If the spindle is bucking in any, the bit will bounce rather than bite. You shouldn't be having to push anywhere near as hard as you are. Maybe it's time to rethink the mount.
    Have you successfully done any plunge cuts with the bit? (assuming it is plunge capable)
  26. The Dude
    I cut some pine with ease and it came out clean and smooth. Go too fast and it chatters. I guess the bit was bouncing like you said. I don't have any other way to mount it except like Robert did with the angle bracket and no bearings but I was trying not to burn out the bearings on the motor. Sigh, guess I can remount it...
  27. Rick 2.0
    Consider cutting a V-shaped notch in a couple blocks of wood and wedging them behind it. Cinch it down into the notch and that will give you a good grip with minimal contact so you can still easily dissipate heat.
  28. The Dude
    What about making the mounts out of plexiglass? I think they'll hold together long enough to mill some aluminium replacements...
  29. Rick 2.0
    Any material is probably fine, the main goal is just to get it wedged into something with a wider spread to stabilize it. Notice how Mark has the spindle wedged and tightened into a V-shaped support on the OX build.
    Photo credit kram242
    It's mainly your lower mount that appears suspect, but it wouldn't hurt to apply the same principle to both. Once it's solid, you still have to deal with the play in the wheels.... Sorry, no suggestions there.
  30. kram242
    Robert the last pictures you posted look fantastic! Well done :thumbsup:
