Laser V
    Ahh ok :) I sized them for m3 good deal
  2. Woodie49
    Woodie49 Journeyman Builder
    Robert, What's the Stinger V?
    Larry
    Aw good eye my friend lol
    It is a small to medium sized mill with the ability to mill 1" thick material.
    Mine will be used for PCB milling :)
    I am putting together 10 limited kits that will only require the v slot and a few other items from the open builds store.
    The first kit is done and the prototype is just waiting on the electronics :)
    There are some sneak peek videos on my YouTube ;)
  4. Woodie49
    Robert, Looks good! Keep me posted.
    What are you useing for a power supply( in the video) ?
    Thank, again
    Ty :)
    Just a small 12v 5 amp switching supply off eBay, I will be using a 12v 30 amp from OpenBuilds for the final build
    The motors will also be swapped out as the ones on the test unit are 100 step instead of 200
  6. JCPhlux
    JCPhlux Journeyman Builder
    As soon as I source all the parts that are out of stock or not sold on openbuild I am pulling the trigger so at the latest it will be two days. How do I get on the prototype list for the laser Plate :)
    Let me see what I can do for the laser plate, are you planing on using a nema17 motor?
    I may even have a spare diode housing here some where
  8. JCPhlux
    Wow that would be great. This will be my first try at laser cutting/etching. I have worked with mema17 in the past with my shapoko so that is what I was planning on using.
  9. JCPhlux
    Also is there an alternative to the GT2 (2mm) Aluminum Timing Pulley "out of stock" that will still let me use the belt in the grove technique.
    Ok I will take a look before I go to bed
  11. JCPhlux
    Robert,
    At first I am wanting to cut/etch foamboard and maybe some other thin materials. What are some good suggestions on entry lvl diodes.
  12. Robert Hummel
    This would be my suggestion
    http://m.ebay.ca/itm?itemId=170898388161
    I milled something up fast before bed and I did have the extra diode housing to go with it.
    PM me your mailing address ;)
    JCPhlux likes this.
  13. JCPhlux
    Wow, that looks great. I have my nano on order and will place my order for the rest of the parts tomorrow.
    I believe the pulleys are due in soon
  15. JCPhlux
    I found some on ebay and they are on the way.
    I was about to place my order and they are out of 8mm Low Profile Screws M5 :banghead:. Are 10mm too long?
  16. JCPhlux
    I have my laser, Lens, protective glasses ordered. I will have to check if my power supply I was using on the CNC is is 12 volt and if it is I am good there. All that is left is ordering the parts from openbuilds.
    Looking at what is in stock will the 10mm screws work or will they be too long?
  17. JCPhlux
    @Robert Hummel any idea on the ETA on the ETA of 8mm Low Profile Screws. I am ready to buy just need screws to put it all together.
  18. Robert Hummel
    Sorry for the delay as I just finished a 16 hour shift at the day job.
    I'm not sure of the stock issue I just had a heads up as I was also looking to get the 20 tooth for my other project.
    I will be headed to the post tomorrow and will send the plate and housing your way
  19. JCPhlux
    no worries. I am maybe getting overly excited so I have started posting more. :thumbsup:
  20. JCPhlux
    @Robert Hummel You think you could post a pic of your end stops
  21. Robert Hummel
    I was using limit switches but decided to switch to optical.
    Just have not gotten around to building them.
  22. JCPhlux
    So you have not had any mishaps not using one?
  23. JustinTime
    That's the best I've seen in a long while. Can I quote it, PLEASE. [​IMG]
  24. JCPhlux
    LOL, copy and paste mishaps :p
  25. Robert Hummel
    None as of yet because I set the scale of my drawings to within the travel zone, also use a software limit in grbl
  26. JCPhlux
    Yes but with multiple passes and depending on the color, the number of passes will very.
    If your talking any white plastics no.
    White foam I think so paper also.
    It has more to do with how the material absorbs the beam
  28. JCPhlux
    Thin ABS Black, Balsa, Foam Board white/black, 1/8 plywood maybe.
  29. Robert Hummel
    I would say yes to all, some will cut faster then others.
    Be aware of the fumes and smoke from said items as they may be harmful.
    I have mainly used mine for etching and cutting 3m wrap for automotive use
    I'm sure you will find many uses for it
