Laser V
  1. JCPhlux
    JCPhlux Journeyman Builder
    My parents are wanting me to cut patterns for quilts and cloths with it. :eek:
    Fabric I know for sure as I cut a square in my carpet lol
    kram242 and JCPhlux like this.
  3. JCPhlux
    LOL, I would love to see the reaction video on that one. :ROFL:
  4. JCPhlux
    @Robert Hummel when ordering acrylic panels for the walls and door how do you know if it will provide the proper protection?
    I don't know for sure if the red really protects and that is why I always have my eye wear on when operating it.
    I do how ever know that all scattered light that I had before is now gone after adding the side panels
    I simply went with the darkest red because Red absorbs 445nm light
  6. JCPhlux
    Ok I will make sure everyone has a pair then.
    Yes please do, for the cost it's not worth the risk. I have seen 2 pair kits for $20 on ebay
  8. JCPhlux
    the one's I got where really inexpensive like $4 and they protection Wavelength: from 190nm to 540nm
  9. JCPhlux
    Ugh.... Where are the 8mm m5 screws at. :cry:
  10. JCPhlux
  11. Robert Hummel
  12. JCPhlux
    That would be great. I am ordering ShapeOko end plates for my build so if those will work I can add it too my order with out much added to shipping.
  13. JCPhlux
    Well I got my Diode in today. Hope it is good, I was not very impressed with the packing.
  14. kram242
    That's how mine was packed as well and I was not very happy with it either, but these little buggers look tough so all should be good. :)
  15. Tweakie
    Hi guys,
    Please excuse me chiming in here, it's just a heads-up...
    When constructing or experimenting with diode laser control circuits many have found that the 'lasorb' has been proven to be well worth the investment in protecting the relatively expensive diode laser from ESD and associated surges etc. http://www.lasorb.com/
    Just a thought.
  16. JCPhlux
    @Robert Hummel Do you see a need for this on your controller design? Also did you get a chance to check the clearance on the screws?
  17. Robert Hummel
    I have not damaged a diode to date but it's always good to be safe then sorry.
    I always use an ESD strap when working with my electronics
    I did find a screw and it's a close fit, with out taking things apart to really test fit it I can't say for sure :/ and the screw is to long to try
  18. JCPhlux
    ok thanks for trying.
  19. Woodie49
    Woodie49 Journeyman Builder
    Any pointers for get the racking (side to side movement) out? Also my wheels don't turn feely.
  20. JCPhlux
    Man a video would be great but if your wheels are locking that could be the source of the issue. You might loosen them up and get some lock tight to keep them from coming loose.
  21. Woodie49
    When I loosen them up I get more racking.
  22. JCPhlux
    Are you using Eccentric Spacers?
  23. Woodie49
    No, the plates I got from Robert have oblong holes in them.
    If you have used 2 motors on your Y axis your raking is coming from the setup.
    If you used 1 motor then that's the issue.
    Another thing thang can cause it is the belt being to tight post dome pics or a video so I can see just what it is your having issues with
  25. JCPhlux
    It is done.... I placed my order and now I just have to do the waiting game.:thumbsup:
    For the button heads?
    If so I was thinking that really it's nothing a M5 washer can't fix ;)
  27. JCPhlux
    No I ordered my hole kit.
    Black V-Slot 20 x 20mm X 2
    (Length: 1000mm)
    Black V-Slot 20 x 40mm X 3
    (Length: 1000mm)
    GT3 Timing Belt - By the Foot X 12
    LD2X Laser Driver Board X 1
    Low Profile Screws M5 X 1
    (Length: 10mm/25 Pcs)
    Mini V Wheel Kit X 12
    Motor Mount Plate X 2
    Nema 17 Stepper Motor X 3
    Slot Cover / Panel Holder X 5
    (Color: Yellow)
    Tee Nuts (25 Pack) X 3
  28. Robert Hummel
    Sweet! :thumbsup:
    If you need help setting things up let me know.
    A lot of info is located in the controller section of the forum for reference.
    Oni305's software is awesome and the Inkscape plug-ins listed in the build work well
    Freakin laser beams! :p
    Please take cation! You only have one set of eyes, while setting it up or any time there in power to your laser have them glasses on.
    oni305 likes this.
  29. Tweakie
    Sage advice Robert :thumbsup:
  30. Woodie49
    I don't have the motors hookup.
