Laser V
    That's why your having issues I think but with out pics or vid I can't tell.
    Are they just not hooked up or not installed, are pulleys and belts installed
  2. Woodie49
    Woodie49 Journeyman Builder
    The pulleys and belts are not installed.
  3. JCPhlux
    JCPhlux Journeyman Builder
    Yeah I am excited. I am clearing out a spot in our guest room to set it up.
  4. JCPhlux
    Do you know or could find out real quick what the diameter of the diode housing is?
    Just finishing up an OX plate give me 15 and I will caliper mine for ya
  6. JCPhlux
    16mm dia
    50mm length
  8. JCPhlux
    ok great
  9. JCPhlux
    ok, one more question how high up is the first ring. Sorry I am being so pesky.
    1.5mm
    Then the same in spacing
  11. JCPhlux
    ok thanks I will leave you alone for now ;) maybe
  12. JCPhlux
    I have been thinking about air assist and I came up with this. It is a rough draft. What you don't see if the lip that pushes air across the fins in the diode housing. The hole in the back is 3mm for mounting.
  13. JCPhlux
    So I thought "Man it would be cool to cut this out on a laser" I came up with a plan that would be cut out of 1/8 material.
  14. Tweakie
    Very neat idea @JCPhlux especially the assembly location pins. :thumbsup:
  15. Wojtek
    Wojtek Journeyman Builder
    Could you tell me what is the max size of the possible cutting and how thick balsa can it cut through and because i am not the only person going to use it is it possible to just put in a piece of 6mm depron or foamboard(after cutting balsa) and do both cutting through and cutting part of the way
    Thanks In Advance
  16. Wojtek
    It seem that the laser isn't included in the part list what would the parts for the laser be and is there anything else not included in part list I will be using the laser for 3mm balsa and also 6mm foamboard
    Thanks In advance
  17. JCPhlux
    At this stage I am still building mine. @Robert Hummel might have a better real world idea as to what it can cut. I know that the power of the laser "Watts" does matter and the wavelength "mine is 445nm 2w blue diode but will run at 1.5w". It etch wood but to cut it you ether have to do very slow passes or multiple passes. When dealing with a low watts laser diode the problem is scorching of the material as it is not as powerful as a 40w or higher co2 laser so the material surrounding the target cut zone builds up heat and scorches or burns also.
    Another factor is the absorption spectrum of the target material. A 40w laser can cut clear acrylic like it is not there but the surface might not even get hot with a 1.5w laser so the darker the material the better the absorption rate.
  18. JCPhlux
    The parts list is more of a suggested list. There are 3 things not listed
    1. Laser diode - E-bay is where most people get theirs.
    2. Laser Housing - E-bay o_O
    3. Laser Housing plate. - I lucked out on this one. Maybe coming soon to openbuild?
    I will be putting my build list together and posting it once I get all my parts together.
    Could not say better :)
    Heads up to all that all of my builds will be this way, easy to build with variables that you decide on to suit your requirements.
    The things left out are the parts of my builds that can be substituted for other items or ideas
    I'm sure your creative minds will solve any issues and I'm here to help as much as I can :)
  20. JCPhlux
    I got a little package in the mail today.
    In my mind I know how small these parts are but you just don't grasp it until you well grasp it:p
    Anyway they look great. Cant wait to get the rest of the parts to build it all.
    Thanks @Robert Hummel
  21. Wojtek
    do you where i can get a Laser Housing plate is it possible to use this http://hobbyking.com/hobbyking/store/__37418__Arduino_MEGA_ProtoShield_V3_Expansion_Board.html as a Laser Housing plate
    What would be a good size laser for cutting through 3mm balsa and can also cut through Foamboard and also do indents in the foamboard(the foamboard has a paper covering i just want to cut just up to the 2nd paper for the indents) i know this is certainly hard but is it possible. since it's not too expensive would it be possible to swap out the laser for when i want to cut balsa and when i want to cut out foam and what would be a good laser for balsa and for the foamboard(http://www.foamboards.com.au/store/store_foamboards/5mm-foam-board-sheet)
  22. JCPhlux
    No need to change out the Laser. There is a Voltage adjustment on the LD2X and it will add life to the diode to run it at a lower power than it is rated for.
    I am not sure if that protosheild is going to do the job. I will try to think up a simple solution.
  23. Wojtek
    Thanks now i have to choose a laser. What would be a good laser for me(if you don't know just tell me and i will ask somewhere else)
  24. JCPhlux
    I ordered a 2W 445nm M140 Blue Laser Diode I just searched Ebay for the best price from a reputable vendor. I will be running it from 1.0 to 1.5 watts to save life on it.
  25. JCPhlux
    @Wojtek sounds like you are wanting to build some RC planes with your laser. :thumbsup:
  26. Wojtek
    How did you guess :)
  27. JCPhlux
    You are asking almost the same questions I was. :thumbsup:
  28. Wojtek
    Just for confirmation can the 2W 445nm M140 Blue Laser Diode cut through 3mm balsa or are just saying you will find out when you make it
  29. JCPhlux
    I will be doing full test on the below materials and will be adding others as I get them. What I will be testing for is. Etching, cutting first layer "Foamboard", Cutting 50%, Cutting 100%.
    1. Foam board Black
    2. Foam board white
    3. hobby ply .125
    4. balsa .125
  30. JCPhlux
    I tossed this together real quick. It wold make a good adapter for the laser holder to the Open Rail Gantry Plate.
